Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
advanced alert ip grouping
nivnivo
how do choose range of ip addr to be monitor for example 10.101-107.1-254.10 all ip i want to monitor ends with .10
can i use 10.*.*.10
Find more posts tagged with
Accepted answers
All comments
vhcato
I tried something similar, but with no success. It appears that the IP address is an absolute match, and wildcards aren't allowed. There is an option for "starts with", but not "ends with".
Can you key on some criteria other than IP address? Since they all end in "10", I assume they are possibly the same type of device, perform the same function, and possibly have the same naming convention. Could you key off the name?
Vic
nivnivo
thank i want to use ip so i can use the suppretion easier because
the topology of the ip is hyrarchy
vhcato
Maybe someone else has an idea of how to do this. Short of that, your best bet may be to use some other criteria. Perhaps you can assign a custom property value and use that as your identifier. We use custom properties quite extensively, as it provides a single point of presence to control many aspects of our Orion installation, including alerts.
Vic
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
