Auto-provision new paths sounds useful too!
NetPath Widgets on dashboards.
Since you asked... sometimes when non-routable IPs are used for heartbeats/management interfaces between monitored nodes, those IPs are mismatched to IPs used on transit tunnels across the external/commercial networks. I would prefer to customize the hops in NetPath so some nodes do not get matched to the monitored topology.
Alerts when paths change resulting in new traffic latency costs--both faster AND longer costs.
Netpath widgets on dashboards
Higher resolution with regard to the frequency of the probes. Seconds instead of minutes.
like https://thwack.solarwinds.com/members/stevenstadel says... Widgets on dashboard
NetPath widgets, the ability to link directly to a map, better organization of the NetPath page (ability to sort, limit results for some users, etc)
trafffic quality to endpoint
Visualize traffic flows
to see network latencies in netpath in decimal points. At present i can see latencies which are less than 1ms Netpath shows them simply as "<1ms"
Linux OS support for the agent/probe.
Alright!
