Adding Cisco ASA is very good, but ASA line up will be soon EOL and replaced with FirePower 2100, 4100, etc. It would beneficial to add support for FirePower and Palo Alto deep Integration support for things like VPN Tunnels, ACL Filters, etc.
Please add Firepower monitoring
Please add Cisco Firepower as is essential
Solarwinds is a bit behind the ball on this one. This should be a mandatory requirement. Largest network device vendor and cant support their firewall?
Please add Firepower Support
Anyone heard of if they're working on this? I've found in THWACK some people have written their own CLI templates but it still isn't near what we need as far as FTD support.
Yes, we desperately need Firepower and FMC support!!
Please add Firepower and FMC Support.
We need this feature in SolarWinds NPM. Please add it ASAP.
Cisco makes SNMP MIBs available on their website for the FirePower , but you need to do a little digging. For example, cisco's currently recommended version as of 20200331 is 6.4.0.7 . You can't find MIBs in the 6.4.0.7 software section, but you can find them in the 6.4.0 section. The current 6.4.0 MIB zipfile has 77 files in it, so there is a lot for SolarWinds to choose from if/when they add more SNMP support.
Please add Firepower with VPN support!!
