Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Moving the NPM Website
dwalley
Does anybody know the steps to moving the website from one webserver to another ?
Find more posts tagged with
Accepted answers
All comments
Grabowski
I did that a year ago. As I remember it as being very straightforward: Downloaded the Additional Webserver (which is seperately licensed), Ran the installation and ran the Configuration Wizard. The only issues I had was that if you have any Application Monitor or Wireless Management packs they need to be installed on the new server as well. Then you need to MANUALLY copy the reports directory and any custom icons you may have made. Finally, in Mapmaker, you need to specify the path to the NPM folder on the remote webserver (which was what caused me the only real problem.
It works very well for us. The only annoyance is that the "export to remote webserver" function only handles maps, and completely ignores any reports you subsequently create for your web-users.
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Currently using:
Cirrus Version 2.1 DL-500 Feb. 2006 (8.1.42)
Orion Application Monitor 7.8.94
Orion Web Engine Version 7.8.133
Orion NPM SLX 7.8.5 March 2006
Alert Manager 8.1.15
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
