IF YOU TAKE THIS POLL BEFORE FRIDAY FEBRUARY 23RD OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
\m/
there already *WAS* AI in the 60s, so...not much has changed, to be honest.]
Star Trek S2 E24 "The Ultimate Computer" / Recap - TV Tropes
They knew what would happen with AI back in the 60's
I, for one, welcome our robot overlords.
