Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Reports and text alignment
skaczkowski
All,
I'm playing around with the report writer and have a question with the formatting of the reports.
The report I've created is based off the 'Average/Peak Traffic Rate - This Month' with various additional fields,etc. Anyway, I broke my report down into:
Location
Device (Router)
Interface
So that the report shows the location the devices at that location, then each of the interfaces on the devices with the report showing the average utilization of those ports, like:
Milwaukee
router-1
s0/0 1.0Mbps 1.0Mbps 1.0Mbps
I get the information I'm looking for, but for some reason I can't get any of the columns to line up at all.
I've played around with the Alignment setting in the Field Formatting area which doesn't seem to do anything nor does it seem to do anything if I change the Column Width.
My interfaces have somewhat large descriptions in them (via Cisco description command) so could that be throwing it off even though I've set a maximum Column Width?
I'd like it to just throw the BPS stuff at the top WAYYYY over to the right so the numbers are to the right of my interfaces, now they're below them and it just doesn't make sense..
Thanks in advance!
-Steve
Find more posts tagged with
Accepted answers
All comments
skaczkowski
Playing around a bit more I discovered a few things that I thought were interesting.
First off if I run the report via the Report Writer and export it the report it looks great, just as I expect it to.
But again, if I run the report via the web page (Or Report Generator) nothing lines up correctly. It seems that there is a limit or something set that won't allow the pages that are being generated to go over a certain width, I noticed this in all the existing canned reports too.
So, with that being said is there a way I can adjust the settings for page generation? I found a couple config files that appear to have something to do with it, but I'm not quite sure what I'm really looking for..
Thanks!
-Steve
skaczkowski
Ahh HA!
I guess it just takes time playing around with it before you figure out what all the widgets do!
Seems that I was grouping a bunch of fields together in the Report Grouping instead of just one field!
Looks great now!
Hopefully others can learn from my mistakes, I guess that's what this forum is all about..
-Steve
Network_Guru
Hey Steve,
I've never really run into this issue, but you might want to try report grouping.
It will reduce the width of the web page, by grouping common elements into a sub-group under a common heading. I use it to create monthly outage reports based on site.
All outages for each site for last month are grouped under each site name.
You may be able to do something similar for this report.
You can even format the header with custom font, background color etc.
...makes the report much easier to read
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
