Without being able to check the costs it is hard to say if it is value for money.
If you need help, Deployment Services is a good alternative. If you love working on your own and reviewing the documentation, it is readily available.
What's the cost for each tier? Every day provides a link, but not this one. Hard to answer a question about value without knowing the cost.
Surprised by the results of this survey!
Never used it. Have always inherited a deployment and then had to 'fix' it.
I think Im early
