how to become beta tester.
would anyone suggest or guide how to complete beta tester missions or get beta tester points.
Hi. The best way to be aware of betas coming out in the future is to follow the Product Blog. You'll be able to sign up using your Customer Portal account info.
Tulsi,
Would I be correct that to get to be a Beta Tester we need to follow the Blog of that particular Item or Module via the Customer Portal with active maintenance?
Kind Regards,
Dan
Hi Dan,
You should be able to see beta announcements on the Product Blog, or under the product forums for individual products. In the specific beta announcement page, there will be a button to sign up, which leads you to a page that asks for your Customer Portal login information.
Hope that helps!
Tulsi
Yes, thank you for your feedback.
I got some good feedback from Kellie also.
As with my reply to Jeremy it is finding and making the time to get registered, download, install and Beta Test...
