Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
SolarWinds reads fract ional T1 incorrectly
rmiller19
We have recently rolled out the Nortel Contivity 1740 secure router and I have discovered an error while monitoring the T-1 min/max/ave utilization. The FT1 module is a full T1 (all 24 channels), but SolarWinds is reading it as a 56K. I wish I could get 600% utilization. Can you tell me where SW is getting the circuit size information.
Find more posts tagged with
Accepted answers
All comments
kesteele
I assume you are using Network Performance Monitor.
You can set the bandwidth of each interface by right clicking the interface and selecting "Interface Details".
You can specify the "Transmit" and "Receive" bandwidth.
BK
Initally when you add an interface to NPM, the program reads the bandwidth from the ifSpeed value in the SNMP interface table. So if the device does not report a correct speed, or it has been set to a lower value for routing protocol weighting, NPM will get the wrong value. Kind of a garbage in, garbage out problem.
As the previous replies have said, you just right click on the interface, list interface details, and change in and out bandwidths to whatever values you want.
If you want NPM to get the correct value, you may want to check the bandwidth setting on your Nortel device and see if it has been set to 56KB on your FT1 interface.
BK
Nobody Special
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
