Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Network Sonar
adaniels
I used Network Sonar to scan our Network and was curious about the results. On the results of the scan under "Discovered Machine Types", I noticed 1000 devices listed as "UNKNOWN" and 2 devices listed as Windows XP Workstation. MANY of the "UNKNOWN's" would be Windows 2000/XP Workstations. It showed 1 2003 server, there should be more then that.
Why the discrepancy?
Tony
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Network Sonar can only identify a device if it is able to poll the device with SNMP.
Otherwise it can only "see" the device on your network using ICMP. but cannot report any details.
Windows SNMP used to be wide open using the default 'public' community string, but since XP & Win2k3, it has been locked down. You will have to specifically allow all your PC's to be polled by the Network Sonar PC with SNMP in order to get the PC's details.
www2.solarwinds.net/.../topic.asp
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
