Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
SolarWinds Needs a Port Scanner
aLTeReGo
After the recent rash of various MyDoom viruses it would have been nice if SolarWinds contained a port scanner for detecting the worm. I have a VERY large number of personally owned machines on my network and it would be very easy to scan ports 3127 - 3198 to determine which hosts were infected.
Sure there are numerous programs on the internet that can do port scans, but most of them only do a single host. I'm looking for network wide port scanning for port ranges. Nmap is probably the closest thing I have found that is capable of doing this task but it's far from intuitive. If SolarWinds included such a tool I know it would be lightning fast, accurate and just plain work. How about it?
Find more posts tagged with
Accepted answers
All comments
edward.lewis
There is one actually, although it's not on the toolbar. Dig around in \Program Files\Solarwinds and you'll find portscanner.exe
Network_Guru
Here is the doc in the beta tools section of the customer login:
This is an early, pre-release version of one of our new Security tools for the Engineer's Edition. The Port Scanner allows testing for open TCP ports across IP Address and port ranges or selection of specific machines and ports. Common port names are included with the program as well as the ability to add custom service names. Port Scanner is extremely fast and configurable, allowing customization of the resulting view. Performance options allow scaling of scans to match machine abilities and/or firewall policies. Included is the ability to export to multiple formats allowing presentation of the data in multiple ways.
-=Cheers=-
NG
rpereda
However, you do need a maintenance contract in order to download this program from the Beta section.
RP
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
