Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Database backups with Orion
sfiermon
I want to setup automatic db backups with Orion and have the backups sent to another machine. Can I do this and will it interfere with Orion's monitoring?
Find more posts tagged with
Accepted answers
All comments
dimonet
This is very easy and it does not interfere with collection.Make sure you SQL Server Agent is operating otherwise the process cannot be automated.
Go into the Solarwinds Database manager and right click on your database. For this example we will call the database "netperfmon". Right click on netperfmon and select "Database Backup Schedule" walk throught the wizard and then when you select your backup location you can use name pipes to redirect the file to a remote location. just make sure that the machine running orion has knowledge of that computer location and appropriate rights to write a file there. After that you should be all set and the job will automatically run as frequently as you specify.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
