Check out all the incredible features the Dev team put into this exciting release:
WPM Release Notes
You guys are just pumping out the releases!
Sohail Bhamani
Loop1 Systems
http://www.loop1systems.com
you have no idea...a release here is like a space shuttle launch, but we love itl
