Simplify and automate these patches and more with SolarWinds Patch Manager.
The Patch Manager catalog contains the following products:
Adobe
Apple
Mozilla
Change History (current month + 2):
13-AUG-2021
29-JUL-2021
22-JUL-2021
01-JUL-2021
29-JUN-2021
18-JUN-2021
17-JUN-2021
09-JUN-2021
04-JUN-2021
03-JUN-2021
27-MAY-2021
20-MAY-2021
14-MAY-2021
06-MAY-2021
30-APR-2021
28-APR-2021
22-APR-2021
15-APR-2021
14-APR-2021
31-MAR-2021
25-MAR-2021
17-MAR-2021
16-MAR-2021
04-MAR-2021
02-MAR-2021
16-FEB-2021
11-FEB-2021
11-JAN-2021
23-DEC-2020
17-DEC-2020
14-DEC-2020
10-DEC-2020
09-DEC-2020
08-DEC-2020
03-DEC-2020
01-DEC-2020
This is a frustrating way to post the updated patches. Most of the patches listed for today's date were released on 7/27 and 8/5. I was hoping to use this list as a quick way to see updates when they are posted since the "All Packages" list in Patch Manager takes over 10 minutes to load. Patches are not released soon enough and this list always seems out of sync.
It would also be much more helpful if there was one page to bookmark that stays updated instead of a brand new page created every time there are updates.
