Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
IP Address Manager (IPAM)
IP Address Manager (IPAM) Feature Requests
Can I create groups using API in IPAM? Suggest me please
arindam_kundu
I want to create groups and after that i will try to add subnets.
Find more posts tagged with
Status: None
Comments
jm_sysadmin
My gut says no, I had to manually set up the groups the last time I needed to.I just breezed through SWQL studio to see if I was missing anything, and it looks like groups are really just fancy custom properties, but I don't see a way to update them. I think they live in: IPAM.GroupNodeDisplayCustomProperties and it says you can't create or update it.
https://us.v-cdn.net/6038570/uploads/commentfiles/fb5d84b10a5745448a7a45dafc1faa43/ed3fc889/dd69/43cf/ae39/8211eafbc29a/pastedimage1615989447481v1.pngI
might be wrong, @ me if you figure something out.
caneruguz
Hi
@arindam_kundu
, this support page will give you more information about what you can do with the API:
documentation.solarwinds.com/.../IPAM-SWIS-API-to-perform-IPAM-operations.htm
It doesn't look like it's possible to do this with API. We have some documentation for doing it on the application:
documentation.solarwinds.com/.../IPAM-create-groups.htm
Can you tell me more about why you would like to do it using API? If this is an important request we can create a feature request and allow others to vote. Thanks!
arindam_kundu
As we have big customer environment, I need to create more than 500 groups in one go. If we can use api for this creation, it will be helpfull.
caneruguz
Thank you this is useful context. I'll look more into this and convert to feature request.
arindam_kundu
Thank You
frak
You can create subnets, and set some properties via the API. the rest needs to be done with SQL.You may find this of use. it creates subnets and supernets (but not yellow groups).
thwack.solarwinds.com/.../cloud---aws-only-for-now---api-integration-for-ipam
arindam_kundu
Thanks frak.
gregthompson
Need this!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
