Is anyone having trouble updating Java and having old versions left behind, despite using the recommended switch (/s REMOVEOUTOFDATEJRES=1)? Anyone working around this successfully?
We introduced a new method to remove older versions of Java as part of an update task. You can view the steps here: How to uninstall previous Java 8 versions using Patch Manager - SolarWinds Worldwide, LLC. Help and Support
