We have Kiwi CatTools v3.6.0 which backup up a number of Cisco devices no problems - except our CSS's.
The CSS's are running 8.20 and are licensed for SSH. The interactive login sequence is as follows:
login as: test
User Access Verification
Username:test
Password:
test#
Is there a way to configure Kiwi to pass through the username twice before the password (as per the login example above)?
I've checked with the Cisco Support Forums which suggests that this is normal behavior for a CSS running SSH.
Any pointers will be helpful.
Thanks.
