Most of the time when you start troubleshooting a network problem it's best to start at the bottom - at layer 1 - the physical layer. Recently I took some time to discuss Layer 1 of the OSI Model with the readers of Computerworld. Check it out here.
Flame on...JoshFollow me on Twitter
Bookmarking as I have some younger team members that I am mentoring in the Network Essentials.
