Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SMTP Alerts Errors
djwalliker
When the Alerts Actions are set to e-mail with the internal SMTP server address (both DNS and IP) the error log has the entry:-
The transport failed to connect to the server Error Number--2147220973
Anyone got any ideas?
*Anti Virus is not blocking port 25
*SMTP Server allows the solarwinds server IP to connect, and other applications are sending via SMTP from the same server
*The alerts did work but have recently stopped, but there is no SMTP authentication required (even whn I put something in there I get the same error)
All help would be appreciated.
Find more posts tagged with
Accepted answers
All comments
ceclark
Can you successfully connect via telnet from SW server to the smtp server on port 25?
djwalliker
Yes - tried that can can execute helo command..
djwalliker
All working now - not that I had many suggestions!! ;o) Don't know if a Solarwinds bug but when you test the alert it generates log entry saying failed to connect bu tin live environment it works fine. odd.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
