Hi
I can see at from NPM 10.7 you can push that UNDP status to atlas map.
I don't see why we could change the Node general status from OK to something else ?
That could be Green Yellow Green or other color that will indicate UNDP problem.
/SJA
lots of people must be waiting for this since a long time... at least since 2007
It's obvious that a UnDP problem should be displayed and reflected to the node status where a poller is assigned.
hard to understand why this is not yet in production
and that this idea has only 8 votes until now...
thanks
thanks for the vote :-)
It's much like traps& node on maps its run parallel and never meet not real intelligence in that.
I sure solarwinds will do someting about that with the "new alert engine"
This is implemented. See https://documentation.solarwinds.com/en/success_center/orionplatform/content/core-setting-custom-status-sw1043.htm & https://documentation.solarwinds.com/en/success_center/orionplatform/content/core-node-status-contributors.htm
