I have just one switch that i need to backup, its a HP Procurve 5412zl. I notice when i add a device and it says vendor i put in HP, Device Type (Hp Switch 2500 * Only Option), then my only options are for the Models are HP2512, HP2524, HP2600, HP4108, or other. Which one do i put in to pull the config from my 5412zl? I have no username and password setup on this switch, just the splash screen that says hit any key to continue after i have telnet'd to that device. Im also not sure what to put into the stack option. Thanks in advance.
