Currently, NPM web console have dependencies for TLS 1.0. Due to security requirements, we need to disable both TLS 1.0 and 1.1.
I was told that that the older TLS versions are still included for the old report writer and the advanced alert manager tools.
And once these tools have been dropped from Orion, so can the older TLS versions.
There are a number of internal modules that stil require TLS 1.0. It seem though that NPM 12.1 will fully support TLS1.2. Keeping my finger crossed
How is it possible Solarwinds have tools to support PCI DSS 3.1 but their own software cannot run only on TLS 1.2?
Confirmed that NPM 12.1 web interface is not able to work after TLS1.0 and 1.1 is turn off in the server.
We really need this as well, this can't happen soon enough.
Finally, NPM 12.2 is able to work without TLS1.0 and 1.1
cobrien
What about NCM. Can it run with TLS1.0 and TLS1.1?
I dont have NCM so dont really know. But there is another thread which mentioned that it is still not supported.
