@danielleh this question isn't registering as answered for me on the main mission page - can you reset it?
All are actually good ideas, some would be more difficult to implement
I thought I responded to this already, but I did not get a green check.
#2 Dynamically generated traffic maps#3 Expanded load balancer environment monitoring
Commenting again just in case it fixes the "no green mark" for Day 11. Also using exact phrasing for choices 2 & 3, jic.
Visual firewall connection mapping
Traffic information in NetPath
Net Path and Firewall traffic.
Same here
Dynamically generated traffic maps and Visual firewall connection mapping
SD-WAN VPNs in NetPath
1st: expanded load balancer environment monitoring
2nd: traffic conversation deduplication
3rd: visual firewall connection mapping
2) firewall connection mapping
A facility to support reporting telemetry from custom applications we are building on the network.
This question's front-end graphic says it's unanswered. But when I go in to it to answer it, it bypasses the answers, says "answered", and shows the answered stats, showing I HAVE answered it. Strange. @danielleh
Traffic information in NetPath / Expanded load balancer environment monitoring
2 - Traffic information in NetPath. 3 - Visual firewall connection mapping.
Wireless controller/AP maps
Dynamically generated traffic maps / Visual firewall connection mapping
firewall traffic, SD WANs VPNs in NetPath
yes, I have the same issue.
SD-WAN VPNs in NetPath -Wireless controller/AP maps-Expanded load balancer environment monitoring
@danielleh Can you reset the Aug 16 / Day 11 question for me? I answered it but it isn't showing a green check. Thanks!
2. Traffic information in Netpath
3. Dynamically generated traffic maps
Expanded load balancer environment monitoring and traffic information in netpath
traffic information and visual firewall connection mapping
hmm having more data added to netpath like traffic information? YES. Also the dynamic generated maps.
Visual firewall connection mapping and traffic information in Netpath would be awesome!
xxxx
Firewall traffic/mapping and traffic data across the network
Visual firewall connection mapping, Traffic information in NetPath
Visual firewall connection mapping / Wireless controller/AP maps
Same issue here
it's the same here
Same here.
Me as well
