Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Top 10 View
Cesc
Hi All...
I've erased "Top 10" page by mistake.
There is any way to bring it back online? I have no backup, as it's a non-production system.
Thanks for your help
Find more posts tagged with
Accepted answers
All comments
DonYonce
The easiest way to bring it back is to run the "Web Configuration Backup" application and merge the "NetPerfMon Initial Configuration" with the running system. This will restore the "Top 10" view. But... this will also restore anything else that may be missing, such as the guest Account and other default views.
Merging the backup in will not overwrite anything you have customized, it simple reloads anything that is missing.
Before running the restore, I suggest you do a backup using the same "Web Configuration Backup" application. That way if you do not like the results, you can restore it back the way it was by doing a restore with "overwrite" instead or "merge".
Cesc
Thanks Don... but this doesn't fix my problem.
The point is that I was changing menu bars and I mistakenly deleted the "Top 10" menu bar entry, so I'm now unable to bring it back. As the Web Configuration Backup utility doesn't back up menu bars... I can't fix my problem.
DonYonce
I misunderstood you completely. I thought it was the Top 10 "View" that was missing.
Restoring the menu item is much easier. From the Orion Admin page, select "Customize Menu Bars".
The click on the "Edit" button beneath the menu bar you want to change.
Click on the '+' button to add an item.
Check the "Top 10" item and click Submit.
If the "Top 10" item is not found, you can add it back.
The URL is "/NetPerfMon/View.asp?ViewName=Current Top 10 Lists"
Cesc
Thanks!
your advice fixed my problem.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
