Alcatel Device command template for Alcatel model 6850 switch ...which will help to take Configuration backup of the switch using NCM
This is certainly a valid feature request. However, have you tried e.g. this template:
Jiri
HI Jiri,
Thanks for the reply.
I am doubtful that this template will workout..because the command set are all not for alcatel 6850 model.
I tried modifying the template..but I am not able to get the full config backup of the device
Jiri,
Can you help me out with this..I have raise a internal ticket 2 months back and till now I have not got any update.
ticket # 453481
It is a feature request. We will consider it in future releases but can't promise any fixed dates.
Hi
I wrote
[How To] Backup Alcatel OmniSwitch (AOS) with NCM
http://thwack.solarwinds.com/docs/DOC-174783
It works fine
regards
