Every time we run the configuration wizard we have to manually go back into the database and change the name to the FQDN so the alerts work correctly. I am even forced to start/stop services to get this working again and sometimes even have to reboot which is not acceptable.
Ref this link:
Change the Web Console name to FQDN - SolarWinds Worldwide, LLC. Help and Support
Hi, This has already been solved
But I don't want it to change it back every time I run the configuration wizard.
thats my point i dont think you do if you set the above?
