Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Netware Volume space
jebarber
I am evaluating Orion. It is reporting the used space on all my netware volumes higher than they are. It is saying one of the volumes is using 106% of the total volume, clearly this is not the case. I assume it has something to do with the MIBs. From scanning the forums I see that orion doesn't support custom MIBs, which is kind of funny becuase when I called SolarWinds to inquire about this, I was told that it had nothing to do with their software and that I needed to get an updated MIB. What good does an updated MIB do me if I can't use it? Surely others are using Orion to monitor their NetWare volumes. Are they having this problem too?
If it matters they are all Netware 5.1 servers.
Find more posts tagged with
Accepted answers
All comments
FormerMember
jebarber...any feedback from SW on this? We see the same issue with all our Novell servers (running 5.00.10). I posted this problem with SW but have not received any response as yet.
jebarber
Nothing From SW. However I have discovered it indeed has nothing to do with SW. SW looks at the OID 1.3.6.1.4.1.23.2.28.2.14.1.4.# to get the amount of free space. I have looked at that OID with several other utilities and they all say the same thing. I tried to figure out if it was maybe the amount free if all files were uncompressed or if it was not showing purgable space or something. Nothing panned out. Everything I've looked at says this is the correct OID to be looking at. Now I am new to the whole SNMP thing, but it seems to me that this must be an OS issue. Searching the web, I haven't found anyone else with this issue, which suprises me.
jebarber
ok, I take it back. After further investigation, it does appear that it is not including the purgable space. OID 1.3.6.1.4.1.23.2.28.2.14.1.4.# is free space and OID 1.3.6.1.4.1.23.2.28.2.14.1.5.# is freeable (purgable) space. Now it seems to me that this would be back to being a SW issue. SW should be adding the two values together to calculate total free space, right? Is there anyway to do this myself?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
