Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Upstream Orion Server
rob.ellison
does anybody use multiple orion servers in their network and have them all report back to one central box for alerts?
we have a core orion box with a sql 2005 backend, which does all our alert processing and checking for exceptions etc.. the problem is we monitor other sites over vpn's. ordinarily this isn't a problem but for some with low bandwidth connections we get a lot of timeouts. we want to put a separate orion box on the remote site but get the alerts back into the core orion server (or sql 2005) for processing and SMSing out.
the remote site can be running sql 2005 express.
basicly i am looking for a way of reliably sending new alerts (from the alerts table) across the internet to the core sql server (2005).
we have a separate database for alerts which locally is populated using a trigger on the alerts table in the orion database.
i guess we could potentially use sql 2005 web services, but i'm not sure about the reliability.
any help on this would be much apreciated.
Find more posts tagged with
Accepted answers
All comments
Dan.Wendeln
Rob,
At this time it is not recommended to have polling engines across a WAN from the core SQL server. SQL can be very sensitive to latency and the result can be lost data.
Best regards,
Dan Wendeln
SolarWinds.Net
Customer Support Services
FormerMember
Dan,
I was told by Support (within the last 2 months), using the Hot-Standby management Pack, with the HS system set up at a remote backup site, that the HS system could access a core SQL server across a WAN. In our case we have a GE backbone. Was I misled? We are in the process of procuring this pack now and did not plan for another SQL server.
savell
We run two polling engines, one local to the Database server, and the other polling engine at a remote Datacenter (although also across a GE backbone).
No issues at all (both are >3000 elements).
Sav.
FormerMember
Pheew!! I feel a lot better now.
Thanks for your feedback, Sav!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
