nice
O365 API can provide alot of that, Azure has good API so its more for managers to see a nice big green dot :-)
definitely need more cloud monitoring that doesn't require a intermediary cloud based connector
Vast majority of our cloud is AWS. Azure is only there because of O365
We utilize a combination of our upstream providers SW instance for our network monitoring, our on prem connection traffic flow, in combination with external connection monitors for cloud platform monitoring.
Another critical component that could cripple our business if it were not up to par!
Even something like downdetector for their services would be a good idea.
