Hey guys,
Is it possible to add or remove columns on the event grid in the monitor tab?
Diogenes
No, the columns are defined by the "lowest common denominator" of the events that you have in your filter.
IE, a filter for TCPTrafficAudits will have many columns, but a filter based on AnyAlert will have fewer because not ever alert has the same fields.
