We use the Map widget in the group page to show Network Atlas maps of the same name.
The Orion Map widget allows the new, web-created, map to be shown, but this is a fixed reference, not allowing ${Name} to be used to select the map dynamically.
Up!
The dynamic map lookup is such a useful feature in the Map widget - we use this to link Groups to (Network Atlas) maps of the same name. We would really like this same feature for the new Orion Maps widget.
Tom
yes please, would make things much easier
We really need this feature for Orion Map. Otherwise we need to go back to Network Atlas. Thanks.
I did already solve this with a small JS in a HTML control a couple of years ago. Currently trying to get hold of the code (it was just a few lines)
@frak - did you find that code yet please?
Turns out, it is code that will look up and display a VIEW with the matching name. Though we used it usually to include an Orion Map, so that is why my memory was a bit wrong.
Should be easy enough to modify to lookup an Orion Map directly though, if this is not quite enough. (Something I will do when I get a chance)
https://thwack.solarwinds.com/content-exchange/the-orion-platform/m/custom-html/3438
