If you have - was there something you found truly helpful in the comments.
If not, tell us why not in the comments.
I have received an E-mail with a link to some of this information. It has been helpful, in that I've forwarded it to our security specialist at my company.
I'll look when time permits.
The Securing the Supply Chain was pretty interesting with several points I hadn't considered.
I will now that I know it exists
will take a look
I did see the content begin shortly after the breach happened. Until very recently we had all our orion servers shut down completely or only kept running really old versions of Orion. In the past couple months we've gotten many of them current.
Bill
voted
help desk
I had no idea it existed.
Gotta find the time, I suppose!
I'll take a look.
I didn't know it existed.
Not enough hours in a day
have to check it out.
I'll check it out
Never knew it existed
tldn
Informative content thanks.
Hadn’t heard until today, but I’ll check it out for sure.
I too had no idea, checking it out now...
Had no idea about it.
Never heard about it
Never knew about it
Never noticed before but will take a look
Been busy, but will take a look
Well, better late than never… :-)
Thanks for the illumination!!
