\m/
I wrote about this script (and others) on this Product Blog: Manage and Monitor PowerShell Scripts
But here is the script if you need it immediately.
$AllCertificates = Get-ChildItem -Path Cert:\LocalMachine\My -Recurse
# Create an empty list to keep the results
$CertificateList = @()
ForEach ( $Certificate in $AllCertificates )
# Check to see if this is a "folder" or a "certificate"
if ( -not ( $Certificate.PSIsContainer ) )
# Certificates are *not* containers (folders)
# Get the important details and add it to the $CertificateList
$CertificateList += $Certificate | Select-Object -Property FriendlyName, Issuer, Subject, Thumbprint, NotBefore, NotAfter
$CertificateList | Sort-Object -Property FriendlyName
Hi Kevin,
Where can I find the text of that Powershell script? I like to try it out, can you provide a link or the text?
