We would like to announce the general availability of Network Topology Mapper version 2.3.This release contains following new features and improvements
You can find here full NTM 2.3 release notes.For information about requirements, see NTM 2.3 system requirements.Download Network Topology Mapper 2.3 now from your customer portal.
Ivodlouhy,
Why are there no Windows and or VMware Nodes discovered and shown with the SolarWinds Network Topology Mapper demonstration video?
Are there any plans to integrate NTM with NPM and or HCO any time in the future due to the potential depreciation of the Network Atlas.
I will look forward to your replies…
Kind Regards,
Daniel
Hi Daniel, thanks for this question - we plan to update NTM demo video soon.At the moment, I cannot say if any other integration will be implmented as there are a lot of development acitvities on HCO side but on NTM as well. Our general aim is to keep and extend NTM maps export posibilities including path to HCO.
