Dear all,
I'm currently testing Cirrus. I have tried to add two switches HP ProCurve 2524 j4813a.
To connect by SNMP, no problem. To connect by CLI (Telnet/SSH), no problem.
But... when I try to download the configuration, it is not possible...
I click to download the configuration and Cirrus stay blocked on the status : " Receiving Data".
After ~2 minutes, the line become red without error message and status and I have no configuration.
I have tried with "Device Command Template" set to "Auto Determine", or to "HP Switch" but it isn't working.
I see that Cirrus try to enter terminal lenght/width 0 <= not supported by HP ProCurve.
Thanks in advance.
