Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Custom Pollers Crash Report Writer and Sys Mgr
direland69
I'm trying to create a report with Report Writer that displays all UPS' and their current load percentages.
On the Filter Results tab, I add the following elementary condition...
Records where Poller Name is equal to *
When I click on the * to choose the poller name, Report Writer closes and the following two events are logged in the Application Log...
Event Type: Error
Event Source: Application Error
Event Category: (100)
Event ID: 1000
Date: 4/12/2007
Time: 12:17:13 PM
User: N/A
Computer: ORION
Description:
Faulting application OrionReportWriter.exe, version 8.0.0.14, faulting module unknown, version 0.0.0.0, fault address 0x00000001.
Event Type: Information
Event Source: DrWatson
Event Category: None
Event ID: 4097
Date: 4/12/2007
Time: 12:17:13 PM
User: N/A
Computer: ORION
Description:
The application, C:\Program Files\SolarWinds\Orion\OrionReportWriter.exe, generated an application error The error occurred on 04/12/2007 @ 12:17:13.540 The exception generated was c0000005 at address 00000001 (<nosymbols>)
Find more posts tagged with
Accepted answers
All comments
direland69
Apparently this is not just Report Writer. I just tried creating an Advanced Alert based on poller name and got the same results - Orion crashed to desktop.
I am running Orion 8.0.2
direland69
Latest hotfix for System Manager did not correct this issue.
Anyone else experiencing this or have suggestions on how to fix?
FormerMember
I am also experiencing identical problems. Any word on a fix for this?
AaronK
I just had this exact issue... SW tier 3 said to remove and reinstall all SW software on the server. Sux I know.
Make sure you back up your reports and maps folders, and the website under InetPub. I had to remove all of the software, delete the entire solarwinds.net tree from HKLM/Software in the registry, and then download and reinstall the applications again. Don't forget to re-apply the patches too.
I would temporarily disable alerting too, or you'll get slammed when the service comes back up.
In the end, this did resolve the issue.
Aaron
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
