Hello, after having upgraded my Orion NPM from 9.5.1 SL100 to SL250, the Map Maker executable (mapmaker.exe) disapppeared.
I've already tried to reinstall all, but without success. There's a quick fix to have my Map Maker back?
Regards.
Try looking for NetworkAtlas.exe, the replacement for Map Maker.
By default, the executable for Network Atlas is at \Solarwinds\Orion\Network Atlas\NetworkAtlas.exe.
The shortcut can be found by going to Start | All Programs | SolarWinds Orion | Alerting, Reporting and Mapping | Orion Network Atlas
You can also install the Network Atlas client on your workstation. Assuming everything is in the default place, browse to your orion server/NetworkAtlas/NetworkAtlas.exe
Hope this helps!
