Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
"Busiest hour"- type report
Grabowski
Does anybody have an idea as to how I can answer the following question:
What was the average (interface traffic) utilization during the busiest 15 minutes on a given link?
I'm mucking about with the report writer and just can't see how I can this info from the database. I want to refine it with time exclusions for business hours, filter for certain regions and so on, but I just can't seem to get anywhere before I understand how to come up with the answer to the question above. Maybe I need some SQL-skills.
/Lars
Lars Grabowski
Global Infrastructure
Chr. Hansen A/S
Find more posts tagged with
Accepted answers
All comments
Network_Guru
It Depends.
- What is the statistics polling frequency of your interfaces?
- How long are you keeping detailed statistics before rolling them into hourly stats?
- How far back is the report pulling the data?
The most detail the built-in reports will display is hourly data. Unless you are using
custom SQL queries, you won't be able to see the data in a 15 minute interval.
I believe the Report Writer was intended for trending and general historical reporting.
For the kind of granularity you are looking for, the web graphs would be a better option.
-=Cheers=-
NG
Grabowski
*The statistics polling frequency of my interfaces is 120 seconds
*I am keeping detailed statistics for 31 days before rolling them into hourly stats. (used to be 7 days up until last week)
*I'm hoping to be able to pull data a couple of weeks or mopnths time back.
I spoke with Solarwinds Support on Thursday last week, where we established that I can forget about getting local business hours across the globe into one single report. No way of handling the off-set. So, adjusting my expectiations, I wanted to still try and get busiest x-mins during business hours. We kept getting incorrect percent utilization (MAX) data back from the query though, but finally found out that this has to do with us asking for data that went further back in time than the setting for when data was being rolled up/summarized was set at.
Now I've changed the settings for when data is being rolled up from detailed to hourly from 7 to 31 days, hourly to monthly from 30 to 60 days, dailies deleted from 365 to 550 (the database will no doubt grow substantially). So in a couple of weeks time, I'll be able to make this query produce better averages
Basically, what I find is missing is some form of handling of time-zones. And also some sort of documentation of the database including how calculated fields are derived.
Lars Grabowski
Chr. Hansen A/S
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
