I need help restoring a map I accidentally deleted.
I noticed that there's is a cached file of this map on the server under \Windows\Temp
File : DirectLink-f914ec87-12e7-49a4-9248-805d275eab37.OrionMap.html
It also come with a corresponding screenshot which shows it's the map I deleted. I tried removing the .html extension and manually pointed NetworkAtlas. Network Atlas failed to open it and crashed.
Any tips?
