Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Unmanaging multiple nodes on Orion V7
FormerMember
How can I select multiple nodes to unmanage at one time? I had to go into 78 nodes today individually and Right Click/Node Details/Unmanage. This was due to a partial network outage at a location and wanted to remove SNMP traffic while the outage was repaired. I am curious if there is some sort of mass modify option to allow for this.
Find more posts tagged with
Accepted answers
All comments
jtimes
It's not a simple task either, and I really don't recommend doing it for so few nodes. If the repair takes longer than expected (exceeds the unmanaged time) you'll have to repeat the process.
To answer your question though: You would have to stop all polling engines and manually modify the DB. Above the fact that manually modifying the DB carries the same risks and warnings as editing your windows registry file, when you stop the polling engines you are losing data for
all
nodes.
Depending on your polling frequency (ICMP) and your rediscovery / stat collection intervals (SNMP) the traffic generated by Orion should not be overwhelmingly large...
I would think that you would want to know if the repair was 100% complete, therefore leaving them managed would give you the best indication. Best option: Leave them alone during the outage.
John J. Times
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
