Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
POP UP support on solarwind
igrva
HI,
Anybody know how to implement pop up messages on solarwind?
Vikas
Find more posts tagged with
Accepted answers
All comments
Network_Guru
I am using pop ups successfully (send windows net message).
I just put the DNS name of the PC to send the pop up to, and that's it.
Make sure you aren't blocking the pop-ups on your PC with antispam software.
The spammers use this for sending pop-ups, so you may have blocked it
if you are not receiving them from Orion.
-=Cheers=-
NG
DonYonce
Network Guru is exactly right.
In Version 7.x only....
When creating an Alert, add a "Send a Windows Net Message" action to the Alert. Then simply enter the IP Address or Computer Name.
Be sure the Windows "Messenger" service is running on the machine that should receive the popup messages.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
