I would like to create an alert on netflow data when traffic to specific countries is detected.
Is this currently possible in any version of NTA?
The only way I could think of is by using a SQL Alert, but looking at the Advanced Alert Manager (none of the instances I support are on NPM 11.5.x yet, so no web alerts for me), I had a look at this for you, but I can only select NTA CBQoS Class Map as the trigger query.
Based on this, I'm,not sure if it is possible.
was you able to do it ? can you share result ?
