Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
100Mpbs servers peaks at 133Mbps?
Dominic
Hello All,
I'm using Orion NPM V7 SLX on a Win2003 Server (SE).
I don't know if you encountered this problem or not, but I did. Maybe someone has an idea about this..
I am monitoring several Windows Servers (NTs, 2000s and 2003s) and a couple of SUNs and I get "Peak Receive bps" and "Peak Transmit bps" greater than the value set at the transmit and receive bandwidth in the interface details. 75% of the monitored servers have peaks under 100Mbps but the other 25% is between 112Mbps and 197Mbps.
All theses "over the top" servers have NIC with 100Mpbs max bandwidth capability and are connected to 100Mbps ports on WS-C3524-XL-EN switched.
Is it a MIB problem? Is is a NIC problem (reporting wrong info)?
Hope someone has an idea about this..
Ciao!
Dom
Find more posts tagged with
Accepted answers
All comments
BakerD
I have seen the same thing and am interested in a solution or explanation too. Ours is mostly at night when our backups run, a 100mb nic will show a peak of 112mb or so.
Network_Guru
Some vendors rate their 100Mbs switch ports as 200Mbs throughput.
Perhaps their MIBS are rated this way as well ?
-=Cheers=-
NG
psala
Have you tried setting these to 64bit counters? You may be getting rollover errors.
Network Engineer
Emerson Power Transmission
gonzajoh
This is not looking good! I have the same problem with some of our saturated WAN links (Cisco routers) and they are set for 64 bit counters.
In fact, I have had queries from users alleging that they are seeing utilisation mismatches betweek Orion and they're own 'less spectacular' network management systems (What'sUpMan!
I hope we haven't got a generic problem here! This is fundamental stuff.
Network_Guru
You should only select 64bit counters if the device actually supports this.
If it doesn't, you will see a "polldebug.txt" file in the Solarwinds directory.
Here is a sample from mine:
4/15/2004 03:09:Sniff-4519-DSNIFF-LAN1-SiS 900-Based PCI Fast Ethernet Adapter attempting upgrade to 64 bit counters
4/15/2004 09:09:Sniff-4519-DSNIFF-LAN1-SiS 900-Based PCI Fast Ethernet Adapter attempting upgrade to 64 bit counters
To fix this, uncheck the 64bit counter support for the device.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
