Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Orion and Cirrus sharing databases?
skaczkowski
Is it possible for Orion and Cirrus to share a database? I know the long term plan is to integrated the two products, but who knows when that'll be and having to manage seperate DBs for what more or less are the same devices is kinda silly...
Just curious..
Thanks!
Find more posts tagged with
Accepted answers
All comments
chris.conway
At the moment, no. Both have tables with the same names but with different contents.
In the case of the Nodes table for example, the NodeID is formed completely differently.
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
skaczkowski
Ahh.. Thought so..
Hmmm.. Well, anyone have problems running Orion and Cirrus off the the DB server? Initially we're thinking about putting Orion and Cirrus on the same machine but have a shared DB server, both of which will be pretty beafy boxes.
We're probably looking at managing ~2000 nodes in both Cirrus and Orion just to give you an idea of scale..
Thanks!
-SK
ceclark
FYI-
I'm running about 500 devices, both Orion and Cirrus, with SQL, all on one box. Dual Processor 3.0Ghz and 4GB RAM. CPU is less than 10% and memory is steady at 65%. You can never have too much memory. On large reports it craps out.
gbrance
We have both our Orion and Cirrus DB on the Same SQL Cluster
2.8Ghz Dual Core, 8GB Ram 64-bit SQL. The application parts are on a separate dedicated box.
This cluster serves several other databases besides Orion and never gets above 30% CPU utilization. We have about 5,0000 elements in Orion. About 60 nodes in Cirrus.
GB
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
