Any ideas as to why I can't add a single node in node management? I'm getting test failed when I try to validate the polling via the IP address. This is a new switch that we just put on the network and I need to add it to SolarWinds for monitoring.
Update on this issue. Network team had to add my SolarWinds server to the ACL on the new switch.
Presumably because there is something preventing you from reaching the switch with SNMP. Can you putty from the orion server to that switch's IP? Can you telnet from the orion server to the switch on port 161?
I think you're right. I need to get with my network team to see what's going on. Thanks for your response.
There are a few possible reasons why adding your node to NPM via snmp is failing. The easy and obvious ones are:
For best security and easiest AAA:
