Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NetFlow Traffic Analyzer (NTA)
Netflow dropping managed IP packets
Trigon
I'm getting the following error from Netflow:
NetFlow Receiver Service [NETMN_SRV] is receiving a NetFlow data stream from an unmanaged device (192.168.254.9). The NetFlow data stream from 192.168.254.9 will be discarded. Please use the Orion System Manager to add this IP Address in order to process this NetFlow data stream.
This is a managed router in Orion so I don't know why this is occuring.
Has anyone else had this problem?
Brad Swihart
Sr. Systems Engineer
Trigon EPC
Find more posts tagged with
Accepted answers
All comments
savell
Brad,
Is this IP address an interface on the device, or the management address (i.e. loopback).
Check that you hace configured the device to send the Netflow data from the management address (e.g. ip flow-export source Loopback0).
Sav.
Trigon
Thanks Sav, I'll give it a try and let you know the results.
Brad Swihart
Trigon EPC
billh
I get this too on Cisco routers that I only want netflow from on the serial interfaces. I don't want netflow packets from the ethernet interface.
I also get this on a device that has an interface that's disabled, like my Packeteer appliances. I guess there is no way to 'unmanage' just an interface even though it's unchecked in the list of resources.
Trigon
Hey Sav,
Can you give me some more details on using the loopback? I can't find anything on the Solarwinds site about it.
Here is my issue:
Router 1 was defined in Orion System Manager using the fa0/0 (172.16.1.1). It discovers all the interfaces of the router, including S0/0 (192.168.1.1) which is the interface I want to analyze. I setup Router 1 S0/0 for flow-export (version 5) to my NMS on port 9090. Netflow works fine on the router and I can see the stats. However, Netflow Traffic Analyzer (NTA) receives the Netflow packets but discards them as a non-managed packet.
So, I deleted Router 1 in Orion System Manager and then added it back using the S0/0 ip (192.168.1.1) to discover. System Manager found the router and all the interfaces (just like when I used the fa0/0 ip). After a while, NTA started accepting the packets and I can view the details.
I'm not sure if this is how Netflow Analyzer should work but I can't find very much technical detail on the SolarWinds site.
Your loopback solution may help me as well as others so if you can elaborate a bit more it would be great. I want to add more routers to NTA and need a best practice for my ops team to follow.
Brad Swihart
Trigon EPC
billh
Brad, that is the same issue I have...I had to follow the same steps as you to get the netflow packets and to remedy the warnings in Orion.
savell
Gidday Brad,
Sorry, I assumed that you were already using loopback addresses in you configs.
Netflow receiver must be able to correlate the managed device in Orion with the incoming Netflow data.
To do this, it uses the IP address that was used to manage the device.
As you found, if the addresses do not match, then you have a collection issue.
You could have equally used the command ip flow-export source fa0/0 rather than re-adding the device into Orion using the serial interface.
We prefer using loopback addresses.
Consider these to be virtual interfaces.
With a loopback address on a device, you can ensure that all packets originating from the router use the loopback address.
A number of commands are useful to do this once you start using loopbacks:
ip tacacs source-interface
ip tftp source-interface
ntp server xx.xx.xx.xx source
logging source-interface
snmp-server trap-source
Loopbacks then make it very easy to (for example) construct filters to protect management interfaces, map loopback addresses to router names, and to enable telnet to loopback addresses (routers usually have multiple external paths and many interfaces).
Sav.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
