Running daily backups with Kiwi Cattools and I have found that the program and timer do not automatically restart after a reboot having received windows updates. Is there any way to ensure that the tool starts and starts the timer after a reboot?
In CatTools, try going to Options/Setup. Click the Misc tab, and look at the Automatically enable timer section:
I am using version 3.11.5, not idea why the option is not there.... any can help ?
Now I see the option after reinstalled the cattools as a service. Thanks.
Did you install as a service or an application?
