Hi There,
Is there a way of selecting devices based on the contents of the devices config?
For example. Say some (but not all) devices have a line of code
logging 10.10.10.1
and you want to change this to
logging 10.100.100.1
So what i would want to do is..
If "logging 10.10.10.1" exists in the config then delete it and add "logging 10.100.100.1"
Problem is, out 1000 devices I dont know which ones have this line present. Now i know i can query the config files to find the devices that have this line present. This would give me a long list of device names.
However, as far as i can tell this would then mean manually selecting these devices and applying the change. Not a problem with a small number but a bit of a pain if its 500.
Any ideas?
Andy
