Hi there,
Have used this tool in Cisco gear and it works like a charm - have came accross a Nortel 8600 router in which I need to run two commands every hour but not able to get into privilege mode through a scheduled Activity added.
How could I make it go into privilege mode? For device info, all 'Passwords' are entered correctly and logging works with no problem - was able to see this on Info log. Nortel provided privilege password and a shell password - either way I try on Activity added, by list of commands typed in or reading commands from file, by 'Enter commands in enable mode' ticked in or not selected - not able to get into privilege mode and run two commands through added Activity.
Note that doing this manually works with no problem so no issue with incorrect credentials used - it will be the way CatTools treats 'enable mode' which I would say is different to how Nortel deals with privilege mode - any input out there that would be helpful?
Thanks indeed.
