Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitor Bandwidth on PIX inside interface
lansim
My NPM server is sitting in the same subnet as my PIX firewall inside interface. I can monitor the up/down status but the bandwidth graphs show no data.
Can anyone tell me if there is some way to monitor the throughput???
Any ideas will be much appreciated.
Find more posts tagged with
Accepted answers
All comments
zeeshanmasood
I had also face the same problem; what i had done:
I added my Orion SolarWinds Server IP address in one of the NAT Pool and add my servers IP Address enrty in outside-acl, due to this i am able to access my PIX's outside interface and other outside routers and their interfaces easily.
Regards,
Zee
ceclark
Yes, you must enable SNMP on the PIX. Refer to cisco.com, you should find instructions on properly setting it up.
mjhodge
Are you allowing SNMP through your access-list? The Up/Down status uses ICMP which may be permited via an "icmp permit" statement.
spam1
How could you configure email alerts on the bandwidth on the PIX interface, for example once the interface has reached 30GB for the month and email alert is sent?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
